[Blockierte Grafik: http://www.vwvortex.com/artman/uploads/001_001.jpg]
[Blockierte Grafik: http://www.vwvortex.com/artman/uploads/002_004.jpg]
[Blockierte Grafik: http://www.vwvortex.com/artman/uploads/003_003.jpg]
[Blockierte Grafik: http://www.vwvortex.com/artman/uploads/004_002.jpg]
Picture 5
Modifikationen:
Infos:
ZitatAlles anzeigenThe world's first racing development of the new Volkswagen Golf was unveiled today (Mon) by Volkswagen Racing UK.
The wraps came off the Golf Mk V - which is destined for a track career in one of the UK's best supported championships, the Volkswagen Racing Cup - at the Milton Keynes headquarters of Volkswagen UK. Paul Willis, Director of Volkswagen Passenger Cars UK, and Andrew Coombe, head of marketing, performed the unveiling.
Set to make its race debut early next month, the new car is not only the first racing Mk V Golf but is also the first Volkswagen to make its motorsport debut in diesel form. Under the bonnet is a 2-litre, 16-valve TDI powerplant developing 210 PS.
Volkswagen Racing UK has made very few changes to the standard Golf's specification; a limited-slip differential has been adopted and larger front brakes fitted as well as fully adjustable KW suspension. Most of the car's performance boost has come as the result of redefined engine mapping by Superchips and a Milltek racing exhaust system.
"We have deliberately kept the car as close to showroom specification as possible," added Roach, "to underline the point that the new Golf is a formidable proposition even in road trim."
Daten:
ZitatAlles anzeigenGOLF TDI Mk V racing version
Engine capacity (litres / cc): 2.0 / 1968
Configuration: 4 cyl, 16v
Engine management: Volkswagen with Superchips mapping
Power output (PS @ rpm): 210 @ 4,000 (standard model 140)
Max torque (lbs ft @ rpm): 330 @ 1,750 (standard model 236)
Drive: Front-wheel drive
Gearbox: Six speed, limited-slip differential, RCS gear selector
Clutch: Sachs sintered metal plate
Exhaust system: Milltek bespoke system
Shell: Production shell, welded-in multi-point roll cage
Safety: Sabelt racing seat, six-point Sabelt harness, plumbed-in fire extinguisher system
Steering: Power assisted rack and pinion
Brakes: 355mm ventilated front discs, Production ventilated rear discs, Mintex racing pads, ABS disabled, adjustable bias
Front suspension: KW 2-way adjustable race dampers, height adjustable, Adjustable anti-roll bar, solid bushes
Rear suspension: Multi-link production suspension, KW 2-way adjustable race dampers, Adjustable anti-roll bar, solid bushes
Wheels: 8x18in/8x19in BBS alloy wheels
Tyres: Pirelli PZero Corsa 225/40 ZR18 / 225/35 ZR19
Weight: 1080 kg
Lubricants: Castrol
Air filter: K&N
